FlashPro Requests
BrettCombs
Re: FlashPro Requests
Post by BrettCombs »
iselfdevi wrote:2009-2014 tsx cu2
The ability to lock the VTC angle between shifts.
Read the help...
Deceleration VTC Angle
The default behaviour of the ECU is to return to cam to 0 degrees when the throttle is released (during deceleration or decel fuel cut), except in the 2012 Civic Si which will return the cam a target cam angle of 5 degrees when above 4000 RPM. This may be undesirable when changing gear as the cam will return to 0 degrees when the throttle is released, and then take some time to return to normal VTC angle once the next gear is engaged (typically 20-30 degrees at part throttle). Most engines make significant less power if the cam is below 20 degrees or so, so this is undesirable.
may not be applicable for your ride but maybe so
iselfdevi
Post by iselfdevi »
Read the help...
Read this thread.
https://www.hondata.com/forum/viewtopic ... 37&t=19607
2012 Acura TSX 4cyl 6MT - flashpro - ct-e supercharger - ct-e icebox intake - deatschwerks 550cc injectors - RV6 exhaust/pcd - Vit tuned
azn1art
Post by azn1art »
Is it possible to add this to the 2013-2014 Acura ILX since it is under the same category as the 2012+ Si? The reflash tachometer progress indicator and the full throttle shift is helpful.
[2006 Civic Si / 2007+ Civic Type R / 2012+ Si] Added adjustable launch control, full throttle shift, reflash tachometer progress indicator and cruise control lambda display.
steelers743
Post by steelers743 »
also posted a while ago in the s2000 section if the 2.4.9 civic functionality be added for s2k? Or all the cars for that matter
kenneth_1010
Post by kenneth_1010 »
steelers743 wrote:also posted a while ago in the s2000 section if the 2.4.9 civic functionality be added for s2k? Or all the cars for that matter
I've been requesting this for months now, guess ill just wait 5 or so years for at least a response, if they are going to do it or not. But definitely not fair that the Civic Si has those features and the S2000 doesn't.
typer86
Post by typer86 »
Type-R EURO (FN2)
I am very happy to deactivate in the "misc" the annoying "beep" causing the ignition key is in if the door is open!! I know the ignition key is in - why honda do this...
If this could be disabled via OBD this will be cool...
typer86 wrote:Type-R EURO (FN2)
This has nothing to do with the ECU can cannot be disabled via ECU programming.
urdaman
Post by urdaman »
In the civic si 06-11 calibrations, a parameter in misc to disable the ftp sensor (P0453) im from asia we dont have evap canister, and no issue in emission.
myuser
Post by myuser »
New Possibilities / Ideas to FlashPro Manager:
1 - Throttle Plate:
Mapping the throttle plate as a live map and ability
to choose different maps, making more sensible at the track
and less at street. The selection could be holding the main
cruise button on for... lets say 3 seconds and turn it off
within 1 sec allowing to show the map selected in rpm gauge.
For instance 1000 rpm 1st throttle map and 2000 rpm 2nd map.
2 - Start / Stop
Engine Start by pressing and the engine reaches 600rpm or idle point
skip (temporary disable button input) engine start and let the engine run.
Able to stop engine by pressing the same button with parking brake/brake pedal on.
3 - Choose different map
Hold Cancel Button to select from different map.
The selection could be holding the Cancel button on for... lets say 10 seconds.
The rev shows 1 (1000 rpm) for the first map, allowing to choose a different map
with the "RES ACCEL"/UP 2 (2000 rpm) like in live mode, changing the parameters.
The Cancel button, abort selection and acts as normal if pressed.
Thanks and keep the excellent work.
mladjan
Post by mladjan »
I would like to see rev match on downshifts, like competitors have, and like 10gen TypeR has.
dinoc
Post by dinoc »
+1 on rev matching
Euro Honda Accord CL9
R-12914
Post by R-12914 »
Comments color can be edited (in the window "graph templates") to make it possible to make the color more contrasting, so you can read them better like the other templates:
At the moment it is still relatively bad to read (not editable) gray like this:
Thanks!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
kenleung8
Post by kenleung8 »
+1 on rev match down shift.
R-12914
Post by R-12914 »
Bug with the "cancel-button", if i would like to upload a calibration to the Flashpro (cancel-button is not fully visible) like this:
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
rev match is not necessary... You can do it manually:
https://www.youtube.com/watch?v=QXZKRc4UYLw
