Can anyone help me setup a base map for my kswap Lotus?
saxon_schmauderer
Re: Can anyone help me setup a base map for my kswap Lotus?
Post by saxon_schmauderer »
See attached for my normal drive. It felt like I was hitting some kind of cut early on in the RPM range. Not sure if you put in some protection:
10-11 normal drive log.kdl
thanks,
-Saxon
CalibratEd
Post by CalibratEd »
The Vtec side is running lean. I increased the fuel. Create another normal driving log.
-Ed
Instagram: calibrated.tuning
saxon_schmauderer
Did a normal drive with the new tune. It still seems like it is hitting a cut off at like 5psi or so:
10-18 run.kdl
CalibratEd
saxon_schmauderer wrote: Tue Oct 18, 2022 4:48 pm Did a normal drive with the new tune. It still seems like it is hitting a cut off at like 5psi or so:
10-18 run.kdl
The car is still running lean so I added more fuel. Create another normal log.
Talk to you Saturday for the remote live tune session.
-Ed
saxon_schmauderer
Excellent. Didnt see a cutoff this time. Car is pulling hardddd. Feels good. See attached for the log:
I will see you tomorrow for a live tune.
CalibratEd
saxon_schmauderer wrote: Fri Oct 21, 2022 9:29 am Excellent. Didnt see a cutoff this time. Car is pulling hardddd. Feels good. See attached for the log:
Did you turn down the boost? It made about 10psi on this last pull. Load the new file and talk to you tomorrow.
-Ed
Tank3697
Post by Tank3697 »
CalibratEd wrote: Tue Apr 26, 2022 6:36 am Sounds like an interesting build. Can you provide datalogs with wideband data? Have you reached out to your tuner?
-Ed
Hey @CalibratEd could you possibly help me get a basemap set up for my k24 turbo setup. Need to get it started!
CalibratEd
Tank3697 wrote: Sun Mar 26, 2023 5:01 pm
-Ed
Tank,
Sure thing, create a thread with your modifications. I will get to it when I can.
- Ed
Neeechh
Post by Neeechh »
CalibratEd wrote: Fri Oct 21, 2022 8:02 pm
-Ed
hola calibrat, soy nuevo y he visto que podrias ayudarme con mapa base para mi k24a3 turbo montado en un bmw e46, te agradeceria mucho tu ayuda.
CalibratEd
Neeechh wrote: Thu Sep 14, 2023 6:02 pm
-Ed
Hola Neechh,
Hace tu propio hilo de discusión con los detalles de tu carro. Yo to puedo ayudar revisar los datalogs para asegurar que el carro sea manejable. Si necesitas algo más detallado seria un Etune completeo. En to dicusion sube tu calibration y los datalogos.
- Ed
Neeechh
Re: ¿Alguien puede ayudarme a configurar un mapa base para mi kswap Lotus?
Post by Neeechh »
CalibratEd wrote: Thu Sep 14, 2023 7:43 pm
CalibratEd wrote: Fri Oct 21, 2022 8:02 pm ¿Rebajó el impulso? Hizo alrededor de 10 psi en este último tirón. Carga el nuevo archivo y hablamos mañana. -Ed [/cita] hola calibrat, soy nuevo y he visto que podrias ayudarme con mapa base para mi k24a3 turbo montado en un bmw e46, te agradeceria mucho tu ayuda. [/cita] Hola Neechh, Hace tu propio hilo de discusión con los detalles de tu carro. Yo to puedo ayudar revisar los datalogs para asegurar que el carro sea manejable. Si necesitas algo más detallado seria un Etune completeo. En to dicusion sube tu calibration y los datalogos. - Ed [/cita]
Hola, no puedo crear un hilo por que soy nuevo miembro, te importaría si creas tú el hilo porfavor 🙏🏼 te lo agradecería michisimo.
CalibratEd
Neeechh wrote: Fri Sep 15, 2023 1:24 am
Desafortunadamente no puedo. Sigue publicando en los hilos hasta que puedas crear el tuyo. No recuerdo si se basa en la publicación o en cuánto tiempo tienes la cuenta.
- Ed
Neeechh
Post by Neeechh »
Vale muchas gracias
