Hey guys, so heres my issue. Got my car swapped, got it running(on a K20 map) the car runs great for the most part. been trying to street tune. Recently bought a new laptop, and the Wideband isnt showing the data, it bounces right at 14.7 Running a AEM UEGO. Wired into the ELD port. Im running Kpro V3. On my Dell it was reading it perfectly.(only for display purposes) On my new HP its not. Outside of that is there any way to use to Wideband as the P02 sensor and any reason the K24 map makes the car run like crap? I also cant seem to attach the cal files. Previously to the release of V4 i could use the analog input for the wideband and it would work, i hadnt used Kpro in a while and was frustraed when i saw i couldnt do that anymore or im just missing something.
Notes
The UEGO Voltage values are set up.
The map is set up on open loop mode because i cant select external wideband.
Current computer is a HP Spectre x360 15"
Previous was a Dell Pavillion G6(I still have it
I looked thru the forums and couldnt find anything thus my post.
Issues with Wideband and base cal. K24A/EK/KPRO3
BusterWolf
Re: Issues with Wideband and base cal. K24A/EK/KPRO3
You cannot run closed loop from an aftermarket wideband with the v3.
To be able to datalog t he readings you must go into the options, settings and select the wideband and input you are using.
BusterWolf
Which is done. Sorry about that. I meant to list that in the notes on my original post, I have the external source for the wideband selected as the ELD and the voltage reading set in the table below it.
BusterWolf
I cant attach pics so i cant show you either. lol. Sad Panda.
BusterWolf
And is there any specific reason why it changed? I could be wrong but i remember being able to run the wide band as the cars primary privy to Kpro4.
This was not possible with a version 3. This will only work on a version 4 K-Pro.
BusterWolf
Ok, and the other questions in my post? ^__^
what other question?
