Basemap for 2012 Civic Si, 550cc, E85, 3" exhaust, PRL intake
schaffertnathan
Anyone wanna help me out with a basemap for E85 on a k24z7. Much appreciated!
Re: Basemap for 2012 Civic Si, 550cc, E85, 3" exhaust, PRL intake
Use a stock map which match your car. Then start tuning.
It is not possible to create a 100% map for each type of modification.
I can e-tune each k engine with each modification. But many hours are required to tune the engine.
@hondata can you create a pinned post with typical etuners which can be contacted to create calibrations/tunes?
Because in this business we must invest a lot of time to read the datalog and setup the calibration. This cycle must be repeat many times until the engine is running perfect/with max power efficiency.
If so I would like to be in your list to make e-tunes for k series engines. Iam specialized for stock, Frankenstein, turbo and supercharged engine modifications.
