kpro at idle on ep3
torkcm
kpro at idle on ep3
Post by torkcm »
I upgrade to 550cc rc injectors and I get misfiring cels at idle and I dont see where I can adjust that.
Now If I have the A/C on I dont get any misfire cels at idle. but once I turn it off and sit idle the a misfire cel will come on. I tested this for 2 weeks with A/C on. Once i turned it off it came on after sitting idle for a while.
I just loaded v7 to see if that may fix it, but wanting to know if there is any where to adjust fuel at idle on the pnf ecu with kpro. I see the pnb ecu has the idle lambda option.
02SilverSiHB
Post by 02SilverSiHB »
what modifications do you have? do you have the stock k20a3 in there and just some na mods?
07 Si Sedan
Razathorn
Re: kpro at idle on ep3
Post by Razathorn »
torkcm wrote:I upgrade to 550cc rc injectors and I get misfiring cels at idle and I dont see where I can adjust that.
What did you gap them at -- are you running boost? How cold are the plugs?
