can not get kpro 4 analog to read psi???
neegzoo4
Post by neegzoo4 »
Anyone here know how to get kpro 4 analog input to read PSI instead Voltage? I change the unit to PSI or bar and it still show Voltage. Oil pressure and fuel pressure is what I'm trying to do.
Re: can not get kpro 4 analog to read psi???
Can you post your calibration and datalog showing the issue?
neegzoo4
Post by neegzoo4 »
Ok here is my calibrations and datalogs that I did. Let me know if I miss anything else.
neegzoo4
Post by neegzoo4 »
Spunkster wrote: Tue May 08, 2018 10:30 am Can you post your calibration and datalog showing the issue?
so Spunkster, any ideas?
They are showing readings. The conversion table you enter must be in BAR, then you can set the unit to PSI , then in the sensor window change them units for each input to psi as well with a reasonable min and max value.
neegzoo4
Post by neegzoo4 »
Spunkster wrote: Wed May 16, 2018 12:55 pm They are showing readings. The conversion table you enter must be in BAR, then you can set the unit to PSI , then in the sensor window change them units for each input to psi as well with a reasonable min and max value.
WOW! change it to bar and it works. Thanks man.
