Missing Hondata System...
turbo_civic_si
Post by turbo_civic_si »
S/N: S200-0468
Been missing for around 2-3 months. little late to post, but doesn't mean i haven't looked for it nor that it can't be found. was bought in 2003 as an upgrade from an S100.
Has Boost & Datalog. Does not have 3 Step or G-Sensor.
Was removed out of blue box and semi-custom mounted inside a full frame USDM P28 ecu. Ecu frame is cut for the datalog cable to fit on the outside part of the ecu. ECU has a 6 position terminal block that is green, has one leg cut to fit the 5 holes. Terminal Block Pic ----> http://rocky.digikey.com/WebLib/Phoenix ... 725698.jpg
I'm located in houston, tx. i do not know if it was sold or if it was kept. i have someone i suspect, but would like to see if someone has it out there and where it came from to trace it back to who i suspect took it. Any info, please email me. Thanks.
esaenz4@stx.rr.com
