Stock primary O2 vs Analog Wideband Input
FlashPro Manager software
balla_EG6
Post by balla_EG6 »
Hello guys
I have an AEM UEGO attached to B29 (EGR) and configured in closed loop as the wideband input.
At logs, I see that past 4000rpm , the stock O2 (corrected) differs from the UEGO a bit. Eg, 0.87 lambda at stock and 0.83 at AEM. No matter what, Hondata uses the Stock O2 for closed loop (even setting the EGR pin as wideband input), so I cant fix my A/F ratio. My WOT target is 0.86.
Thats a bad stock O2 maybe ?
Any fixes besides changing to a new stock wideband sensor?
2004 EVO VIII - www.nrteam.org
balla_EG6
Re: Stock primary O2 vs Analog Wideband Input
Post by balla_EG6 »
just tought about cheating my WOT target to 0.90 to see if my AEM reads 0.86 ...
What vehicle are you referring to?
balla_EG6
Post by balla_EG6 »
Sorry... Civic SI 2008 with K24Z block. Invidia header, Injen CAI, ID1000 injectors, 12.5:1 pistons, ethanol. FlashPRO bt
How exactly do you have the AEM wideband wired (power, ground, signal)?
balla_EG6
Post by balla_EG6 »
Power - ign 12v fusebox
Ground - under fusebox (chassis)
Signal - UEGO white wire to ECU B29 EGRL
Voltage offset 0v
balla_EG6
Post by balla_EG6 »
At low rpm they seem to show very similar AFRs
The uego sensor is 2" from stock
Unfortunately I do not have any way for you to make an adjustment to make them match in this instance.
balla_EG6
Post by balla_EG6 »
I will try a new O2 sensor.
Must be OEM HONDA ?
About the only thing I can think for you to try would be to ground the Wideband to one of the ground wires at the ECU.
