Autotuning? Help or suggestions on how to go about...
LSVtec_Tuner_Driver
Post by LSVtec_Tuner_Driver »
I've got a few questions on Autotune settings and on it's use or more in the ways how to use. Can anyone help me? Anyone?.... here are my questions:
1)Under File>Settings>Autotune...Autotune conditions what values do I want to type in for Minimum and Maximum Lambda for tuning a NA motor and/or Turbo motor? I have right now the values 0 For MIN. 0.15 for MAX.
2)When you press and hold Alt+A as you ramp through both lthe low and high speed fuel table, is RomEditor making changes, if needed to all the cells or is just giving you a percentage+/- for you to go back and change yourself?
3) Would it be a advantage to hit a few hills when you Autotune on the streets?
