Is it just me, or the Pointer Size property of the Bar Graph doesnt get saved on the Display?
I keep setting it to 8 or 10 and when Save and Load it gets reset to default 15
Also a quick view on the save file showed that the property is not stored on the file, so makes sense its not restored.
Is this a know bug, or at least is there any way to report it?
						Bug in Bar Graph?
Re: Bug in Bar Graph?
Works ok here.  What is the exact sequence you are following?  Can you send us the .display file (to support@hondata.com)?
Sorry for the delay, i totally missed this reply.
I checked again, and no, it doesnt work
- I Load my display (attached)
 - Edit the properties of the Bar Graph and set the Pointer Size to 10
 - The Pointer Size DOES change to 10 as expected
 - Save the Display and Reload
 - The Pointer Size is back to 15
I can confirm now that the bug has been fixed, thanks a lot!
PointerSize now saves and loads properly on the displays !
