Hi, new to the forum and flashpro. Tried searching for my answer here but couldn't come close to what i needed. I was wondering if it is safe for me to continue running the 2013 civic si hondata reflash. The reason I am asking is because I am experiencing knocks on about an average of five per data log (20 min runs). These knocks occur mostly between shifting and sometimes during WOT. However, it does not occur while at a steady speed (65mph on fwy).
I am loving the mpg I am getting off of the reflash and the smooth acceleration but not at the cost of my engine. The engine is stock, only modification I have done would be Invidia Q300 catback exhaust.
Attached are some random data logs if someone with experience could take a look at them.
Thank you for your time.
2013 SI Hondata Reflash Question/Help
Raymond0083
Raymond0083
Re: 2013 SI Hondata Reflash Question/Help
So I was looking over the datalogs myself and saw that hondata recommends that i adjust the WOT fuel low. Should i mess with these tables to adjust them to fix my problem? Ex: at around 2k rpm in column 2 it is saying I should compensate by adjusting -13%. Is this advisable? Thanks again.
Raymond0083
Another data log, If anyone could offer any kind of assistance or even point me in a direction on where i could find some that would be great. Interestingly this data log shows knocks in between gear changes. Ex: from third to fourth while tpedal was 0 engine experienced knock and again from fourth to fifth.
Also is it normal for air fuel ratio to bump up to 29.40 during anytime of the drive?
