Need tune
Re: Need tune
Instagram search spectretuned
He might help with base
Re: Need tune
Can some one look at my data,and tune. got a few knocks for about 20min drive.
Maybe some tweaks. if someone wouldn't mine
92 pump
92 pump
Re: Need tune
Your engine is running very, very lean:
You must retune your AFM-fuel.
A optimium s.trim is +/-5
I have retune your AFM-fuel: Please make a another datalog and post it here again!
2008 Honda Civic TypeR FN2
Rotrex C30-94 supercharged with relocated IAT
Powered by ASNU 092/FP330E fuel pump & ASNU 090/750cc fuel injectors
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Re: Need tune
Will have a data log done here in a week or when parts come, clutch is acting up again. Bought a new clutch fork, new stage 2 clutch 4 puck, and pressure plate, and all the other little goodies that go with it. I took for a drive today did a Nice pull then something happen. She not happy.
Re: Need tune
Here is my latest datalog
Re: Need tune
data log didnt really womp on her to bad have to break in the new clutch
Re: Need tune
Here is my latest datalog, with a latest TUNE did a couple good pulls.
How is is my ignition,fuel,etc
If someone can help with knock too
Re: Need tune
Your low VTC profile is terrible:
Same as here (#1):
https://www.hondata.com/forum/viewtopic ... 273#p93278
(#1 Correct the VTC profile - it is very bumpy it is not necessary to use the bumpy start vtc profile - (it is hard to adjust the fuel tables if jumping around the different angles...))
A good and better tuneable VTC profile look very smoother without extreme tips.
A good tuner should know that!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Re: Need tune
Thanks will try again
will post again
And thank all of you for help!!!
will post again
