BETTER GSR Tune - Dyno Tuned - 187whp
Jaythizzo
Re: BETTER GSR Tune - Dyno Tuned - 187whp
Post by Jaythizzo »
Anyone has update on this?
keto06
Post by keto06 »
I sold this car long ago. This motor is currently in my buddies car. Still running strong
07 Civic Si Sedan (sold)
17 Civic Si Sedan (daily)
02 RSX Type S (project)
Hit me up for free Hondata Help!
Kraztec
Post by Kraztec »
Feel this would be a safe tune for B18C Victor X Intake mani, Blox 68mm TB 255lph fuel pump, 2.5" header w/ full 2.5" exhaust system? No cams, stock injectors stock map.
SM0K3YMOUNT41N
Post by SM0K3YMOUNT41N »
Holy sh*t dude. Thank you so much. My car hasn't drove down the street without dying until I found this. Question is where were you located when you got this tune? I am in Colorado springs and the elevation is 5800 ft. Just wondering if there would be anything anyone recommend a because of the elevation? This is on a lsvtec b16 head B18B bottom I/h/e. I need to figure out how to datalog and maybe someone could take a look and tell me why I start throwing a code
keto06
Post by keto06 »
This car was tuned in Texas so elevation and temp are both going to be factors. Last I heard my old motor was still running well. Swapped out of the sedan I sold it in and into a stripped hatch.
JdmGsr17
Post by JdmGsr17 »
This tune causes my Timing to go off ? tried to run this tune 2 times and both times the Timing goes off .... any ideas ?
JdmGsr17
Post by JdmGsr17 »
@keto06 any way I can contact you ? via Email ?
Kingd206
Post by Kingd206 »
butt dyno STOCK JDM GSR
minus SK2 IM
Minus generic 4-1 Header those 300 rep ones (gotta go find me a coo 4-2-1 / tri y but the tri y hang so fucking low i hate it atleast generic ones do)
generic CAI (been meaning make a velocity CAI with it popping out by bumper
2.5" complete exhaust Greddy SP2 axleback (need to upgrade to 3")
Bout to go drive my lil sister to work RN gonna go buttdyno it Let u no i n bit
hopefully someday i get it on a track
try ur tune out 3-5 rounds
try out stock USDM ITR map out 3-5
idk when but ill update ya if it ever happens
reportin back i tried this basemap with bonestock jdm gsr but changed rev to 8200
only aftermarket was the 300$ rep 4-1 header
skunk2 IM
everything else stock 2,5" exhaust
greddy sp2 axleback
this thing sucked
ill try get some cams and valvetrain and redo it
but hopefully others had better luck than me!
still appreciate the basemap i will def try it on other semi builds lol and see how it go
templethor
Post by templethor »
Loaded this up to my car but I'm just running stock cams, but the question is will I still be ok or is there something I need to adjust? Thanks in advance.
Vteciguess
Post by Vteciguess »
Reviving this thread.
Used this tune as a base so for my 98 integra GSR swap.
I only street tuned it so I don’t have any dyno numbers.
Build: all motor
B18c1 non turbo
GSR tranny
9.8:1 forged bottom (CP pistons and Eagle rods)
Stock head
S2 throttle body
S2 pro intake mani
Short ram intake
DC 4-2-1 headers
Stock 240cc injectors
AEM wideband
2.25” exhaust with 3” out muffler
Hollowed cat
Walbro 255
91 octane pump gas
Originally, I had a friend of mine do a previous street tune, and it ran great for three weeks, and then the weather changed to hot, humid and dense. Started running wayyy too rich (8.06 on AFR gauge). Sputtering and struggling at low speed.
Finally got curious enough to run Hondata myself and figure out the issue. Like I said, took a chance and downloaded this tune from OP. Was still running too rich so I increased the overall fuel trim. Went for a rip, was still running too rich during cruising so I opened up datalogging and found the rpm range that was too rich on the low speed table. Decrease the values in small increments. Found the sweet spot eventually 14.7 on cruise and on idle). Changed to 2D view with data logging turned off and smoothed out the values. Car runs great enough for now til I can dyno it.
With love from Canada.
If anyone has questions I might be able to help.
