Hi guys, I've just finished my build and now need a decent map to put some miles on the engine before the tuner will map it. He wants at least 250-300 so the rings have bedded in. Can anybody help me out?
Engine: H22a
Transmission: LSD 4.26 final drive
Crank: H23a
Con rod: Eagle H23a
Pistons: Type S
Compression: 12:11:1
Cylinder head: Full Race Ferrea Valve train with 1mm+ oversized valves, 5 angle valve job + port and polish
Cams: Skunk2 Pro2
Cam gears: Skunk2 adjustables
Intake: Skunk2 Pro series Ported to 70mm
Throttle: Skunk2 Pro series 70mm
Injectors: Sard 800cc high impedance
Engine: Balance shaft del
pulleys: Lightened rosko kit, alternator, power steering, crank
Ignition: MSD blaster coil
Exhaust: Skunk2 4-2-1
Exhaust: Skunk2 mega power "3
Ca: 200 Cell Sport
inductions: AEM 3"
Fuel regulator: AEM adjustable
Fuel pump: 340L Walbro
Fuel filter: High Flow AEM
IN NEED OF A BASEMAP FOR A HIGH COMP BUILT H22A
JustSlowMattEG
Re: IN NEED OF A BASEMAP FOR A HIGH COMP BUILT H22A
bump
very close setup to me
