launch control and full throttle shifting?
hulk252
Post by hulk252 »
So from what I have gathered, there is not going to be a clutch switch with the s300. How does the launch control and full throttle shift work? Forgive me if this is discussed elsewhere but I could not find a answer on search.
Silverbeast
Post by Silverbeast »
It as well as the Kpro is set by MPH. So, say you set it at 6mph (i think this is default) as long as you are at 6mph or less the launch control is active unless you have turned it off in the software.
Maybe that helps explain it a little better.
flip1199
Post by flip1199 »
a/c switch, p/s switch, brake switch, vtec pressure
Silverbeast
flip1199 wrote:a/c switch, p/s switch, brake switch, vtec pressure
These are also inputs you can use to activate it. When you set the launch control as "always on", it follows my description above.
