Hi, I have aftermarket turbo "to4e", in moment check engine light on present p2261, p2263 and VSA, rdx run in 2wd.
Could you disable that code?
There re many people with that problem. In future more and more rdx customer go for aftermarket turbo with flashpro tuned.
						aftermarket turbo rdx problem
Re: aftermarket turbo rdx problem
Also lost boost...
Hi, external boost control and flashpro low value boost control resolve p2261 code but  I ve check engine light on present just p2263 and VSA, rdx run in 2wd.
Could you just disable p2263 code, please? or could I try something more?
Thanks.
Thanks.
That's strange. I've got  precision 5971 and I'm not throwing those codes yet.  I'm having maf problems at 15psi.
I'm getting the p2263 code now also.
Hey.
I have RDX2008.
Previously, gtx3071r was installed. The p2263 engine error occurred constantly due to late boost.
Now installed gtx2976r. Engine error p2263 appears much less often))
Adjustment in the FlashPro parameter BustControl does not help much.
I'd like to disable this code.
Sorry, I do not know much English. For reading and writing I use "translate.google"))
						I have RDX2008.
