FlashProManager 2.6.7.0 & 2.6.8.0
FlashPro Manager software
Changes from 2.6.7.0:
  • Added language translation
  • FlashPro firmware updated to version 111
  • Added support for 2016 Civic Turbo including 5AN-C03 & 5AN-A93/L93
Download here
The FlashPro now supports 30 different ECU variants for the 2016+ 1.5 turbo Civic.
FlashProManager language translation is supported, but no translation files are included with this release.
g-gill24
Re: FlashProManager 2.6.7.0
Post by g-gill24 »
Agh
Been waiting for this..but then I connect my flash pro and it's a dud. Getting a USB device descriptor fail error :( on both my computers
g-gill24
FlashPro bricked after 2.6.7?
Post by g-gill24 »
Hey,
Before this update my Hondata was working fine - was able to upload my ECU and whatnot. but after I downloaded the new one that just released. It recognized my USB/CAR and said it will update flashpro. It did the update and then my Hondata just died? When I go to device manager it says "usb device descriptor request failed". I tried multiple ports/uninstalling driver and reinstalling and even tried it on a different laptop but get the same problem.
Is my Hondata bricked? Am I screwed $800? :(
typer86
Post by typer86 »
Which previous version of the flash pro manager was installed on your PC?
I will wait before update until Hondata drop a comment to this issue....
g-gill24
Post by g-gill24 »
typer86 wrote: Tue May 09, 2017 1:42 pm Which previous version of the flash pro manager was installed on your PC?
2.6.6.0.
The one before this.
First, what version of windows are you using? The instructions depend on the version because Windows 10 does things quite differently.
g-gill24
Post by g-gill24 »
Hondata wrote: Tue May 09, 2017 2:02 pm First, what version of windows are you using? The instructions depend on the version because Windows 10 does things quite differently.
Hey!
It was done on Windows 10
g-gill24
Post by g-gill24 »
I factory reset my laptop and it worked. But sometimes it can't detect my VIN number, I had to reconnect it 3 times to my vehicle for it to detect. Not sure if that's a bug?
First inspect the USB cable and the FlashPro for any problems with the USB connector.
For Windows 10 on a laptop try disabling 'Fast Startup' from the power options.
Then if it doesn't connect open up the device manager and tell us what it shows there.
g-gill24
Post by g-gill24 »
Hondata wrote: Tue May 09, 2017 4:06 pm First inspect the USB cable and the FlashPro for any problems with the USB connector.
Hey,
I ended up factory resetting my PC and that fixed it.
joecang
Post by joecang »
Hi Hondata,
When I installed this new update and uploaded my calibration to my car, it ran really bad and could barely idle. I tried to reinstall the software from your link but it keeps on downloading 2.6.6 but now my firmware has been updated to 2.6.7. I was able to get the car running properly again with the older software but now I am unable to datalog because of the newer firmware.
Any suggestions?
Thanks!
We're aware of the problem and working on a solution now.
Re: FlashProManager 2.6.7.0 & 2.6.8.0
We've made a release to fix the 8th Gen Civic problem:
V2.6.8 (9 May 2017)
• [2006 Civic Si / Type R] Fixed inconsistent injector duration.
joecang
Post by joecang »
Updated to 2.6.8 and working great! Thank you!
typer86
Post by typer86 »
Today updated the firmware from 2.6.6.0 to 2.6.8.0
Issue:
The orange LED is very dark after the update! It is hard to see if the log is started or not.
It look like a little "glow" like a old LED.
Please check it.
My Flashpro is ~4 years old without BT
