Hello everybody,
Here my configuration:
- Skunk2 stage 2 pro series cams
- Skunk2 cam gears
- Skunk2 pro series valve retainers and springs
- 4-2-1 stainless steel header
- RC SL9-310cc injectors
- Hondata S300v3 in P30-G00 ECU with harness
- AEM wideband sensor 30-4110
- OBD1 ignition distributor with harness
If anyone hat a basemap for this configuration or a similar one I'll take it as inspiration. I'm a Mecatronics but this is the first time that I'm remapping an engine.
Thank you in advance.
PS:
- honda Knock sensor would be ordered.
Basemap b16a skunk2 pro 2 cams needed
Zperformance
Re: Basemap b16a skunk2 pro 2 cams needed
I set idle at 1k to hold the idle with the bigger cam. Adjust AFR to spec. Let me know how it works and if there is any problem i will help as much as i can.
