S300 v3 issue
jessesmith86
S300 v3 issue
Post by jessesmith86 »
Turn key on both green lights
Plug cable into computer two green lights with d2 flashing red
Computer says its on line
Says its erasing when i erase
Says its uploading when i upload
I can hit datalog and see sensors
Try to upload stock map on stock injectors and the car wont start.
Using Windows 10 I've uninstalled and reinstalled
Everything seems to work fine.
I put stock ecu in.. Car fires right up.
Any info would be great
Re: S300 v3 issue
Is this a calibration from the New Calibration button, or is this calibration from somewhere else?
jessesmith86
Re: S300 v3 issue
From the calibration selection
jessesmith86
Re: S300 v3 issue
Spunkster wrote:Is this a calibration from the New Calibration button, or is this calibration from somewhere else?
Yes
Re: S300 v3 issue
Are you using an adapter harness?
jessesmith86
Re: S300 v3 issue
Everything is stock for now
Re: S300 v3 issue
What vehicle is this being used in?
jessesmith86
Re: S300 v3 issue
1994 honda civic e.g 2 door coupe.
D16z6 stock car
P28 pcm professionally chipped
5 speed
Using Windows 10..
Windows 7 also.
Tried new cable.
Re: S300 v3 issue
If you cut J1 will the car start with the Hondata prepared ECU?
jessesmith86
Re: S300 v3 issue
Spunkster wrote:If you cut J1 will the car start with the Hondata prepared ECU?
Yes
Re: S300 v3 issue
Are you sure that the s300 is seated on the pins correctly?
jessesmith86
Re: S300 v3 issue
Yes. It seated correctly. Checked it over and over and over.
Re: S300 v3 issue
jessesmith86
Re: S300 v3 issue
39380
2.5.5 or something like one that
Re: S300 v3 issue
so is it or is it not 2.5.5
