i need kal k20a2 ITB OBX
rinkana-k20
Post by rinkana-k20 »
I have a honda civic ep3 engine k20a2, compression 11,2:1 with gasket Spoon, kit cams and ratainers BCrower stage 2, kit valves Ferrea, fidanza flywheels, cluntch stage 4, gerabox with final drive 5.1 and LSD DC5, Header PLM with catback full titanium interior 63mm, PRB Kpro V4, ITB OBX Individual throttle body 52mm and injector RC440, fuel regulator pressure gauge K-Tuned, fuel pump grams 320l/h ...
I live on an island and I have not tuned Hondata nearby. I need a base map and a trainer also online ( I pay ) to put just my car .
rinkana-k20
Re: i need kal k20a2 ITB OBX
hi.. I ran the first start.. i used a base map of Kmanager... someone can take a look?
ce
Post by ce »
I'd recommend you use the alpha-n calibration in kmanager instead. Much better. I've been tuning Hondas with ITBs since early 04 and alpha-n or pure tps like used in Motec and other universal systems is by far the best compared to MAP with ITBs
Do you have access to a dyno ?
K is king
jdm_boi
Post by jdm_boi »
ce wrote:I'd recommend you use the alpha-n calibration in kmanager instead. Much better. I've been tuning Hondas with ITBs since early 04 and alpha-n or pure tps like used in Motec and other universal systems is by far the best compared to MAP with ITBs
just jumping in on this thread. do you teach how to tune? I'm willing to pay also for the lesson and i have access to dyno. thanks.
rinkana-k20
I have finished with my K20a2 .. what do you think?
