all motor b16a calibration in need!!
mitchb16a
Post by mitchb16a »
Iv got a freshley rebuilt b16a with 17, 000km on it. Has a header back 2.5inch magnaflow exhaust, password jdm intake, a set of 2001 USDM ITR cams and springs. Stock Iinjectors. Using a jdm b16 basemap right now but I feel like a little more could be pushed out of it. Runs a bit rich I fined but thats the least of my worries.New to thd Hondata system and dont want to screw something up on my build. All help Iis appriciated!!
cam6222
Re: all motor b16a calibration in need!!
Post by cam6222 »
I have several calibration since i also using b16a. maybe this may help u and u just do some touchup.
Wfb8922 16a.skl
Mrs Autoparts @ Honda Parts Malaysia
Monnoracing
Post by Monnoracing »
only tune I have that has your setup. This car ran good with this tune
Kevinbrahh
Post by Kevinbrahh »
cam6222 wrote:I have several calibration since i also using b16a. maybe this may help u and u just do some touchup.
Wfb8922 16a.skl
Hi do you have basemap for Injen CAI with 421 headers and 2.5 exhaust? I am doing an engine build soon so I don't want to tune my car yet. Thank you!!!
cam6222
Post by cam6222 »
Wfb8922 16a.skl
Hi do you have basemap for Injen CAI with 421 headers and 2.5 exhaust? I am doing an engine build soon so I don't want to tune my car yet. Thank you.
Look for this attachment
PDG45.skl
ecronic
Post by ecronic »
Wfb8922 16a.skl
I know this is a very old thread but could really use your help.
I've got a B16A6 SIR that had a P30 ECU that I sold recently. I've got a S300 ECU but no basemap and the car is just parked now.
Please suggest the best possible basemap you have that matches to the mods below:
B16A6 on stock internals, skunk2 1st gen intake, edelbrok tb, Spoon 1st gen headers & 2.5" exhaust.
Hope to hear from you soon.
Thanks & regards
Dev
Thanks & Regards
Ecronic
Zperformance
Post by Zperformance »
Wfb8922 16a.skl
Thanks & regards
Dev
Hey Dev, you should be able to run your car with a hondata s300 basemap (b16/p30 map). Since you only have minor mods it should be capable to run your car.
ecronic
Post by ecronic »
Zperformance wrote:
Wfb8922 16a.skl
Thanks & regards
Dev
Hi Zperformance
Thanks for replying. I'm just worried about running lean or rich. I've got afr gauge installed so guess I'm going to go ahead with that map and post the result. Let's hope someone can help out then setting up the fuel tables.
Cheers
Dev
Zperformance
Just adjust fuel map slightly to be safe enough. You would always want afr to be slightly richer then lean.
ecronic
Post by ecronic »
Zperformance wrote:Just adjust fuel map slightly to be safe enough. You would always want afr to be slightly richer then lean.
Okay so I tried the s300 cal for b16a/ p30 & the check engine light came on. Errors that shoot up are oxygen sensor heater & knock sensor. My stock ecu doesn't have any errors.
Fyi
Stock ecu: P30 & s300 ecu: p28
Appreciate you replying my posts Zperformance and thanks to anyone who can some light on this.
Cheers
Dev
Zperformance
Fyi
Cheers
Dev
Go through the paramateres and you can disable it. If you are not sure, let me know i will disable them and upload it here for you.
Zperformance
basically P30 basemap i just disable the sensors
