Fuel Injection restart RPM
teddytao18
As I drove my reflashed Si, I noticed that there is a slight acceleration at about 1300 rpm, when I was braking or coasting in gear. I am not comfortable with it, and want to lower it to 1000 so that I can spend more time in gear without shifting to neutral. Anyone knows what I need to change?
pepperdanky
Re: Fuel Injection restart RPM
See "Injector Overrun Cutoff" here: https://www.hondata.com/help/flashpro/t ... meters.htm
The engine may stall when coming to idle if you lower the recover rpm below 1300.
teddytao18
I tried that, it didn't seem to work. I still felt the acceleration at about 1300 rpm, and the power monitor in the imid confirmed it.
pepperdanky
Then 1300 rpm may be the lower limit of what the ECU will allow.
