Excessive knock
smithgrinds
Excessive knock
Post by smithgrinds »
Morning,
I was datalogging and noticed a lot of knock. I pulled the timing but there's even knock close to idle. Can you guys take a look at the map and datalog and let me know if i'm missing something. Really concerned if i have a mechanical issue or my knock sensor is too sensitive?
Thank you.
Set up is a completely stock 08 civic Si + bolton turbo kit with a huge wastegate leak. Max boost is just 1.7psi. With the minimum boost/load i don't think it should be knocking this bad.
Re: Excessive knock
It probably is mechanical contact causing the noise. I'd check the exhaust system is not hitting anything under flex.
smithgrinds
Re: Excessive knock
Thanks it really had me worried that the knock count was going crazy.
Have a great 4th July
