Need a basemap to drive temporary until i find a tuner.
B18c1 Benson 2.0 block
Stock gsr head
skunk2 im
68mm tb
1000cc ID injectors
255 walbro fuel pump
GT28rs ball bearing turbo .63ar exaust housing
RAMHorn exhaust manifold
Need a similar basemap to run on until i can find a tuner since previous tuner no responding to back to me.
Basemap B18c1 Gt28rs
Zperformance
Re: Basemap B18c1 Gt28rs
There you go bro. Im not sure what your wastegate pressure is at so i set it at 9.9psi if you are higher you can raise it under "Boost cut" parameters. This is a basemap so i would advise to have a wideband. Let me know how it do for you, i will try to help if there is any problem.
