kpro4 outputs
dc5itr01
kpro4 outputs
Post by dc5itr01 »
I have a PRC ecu with kpro4. Honda integra type r dc5. 2002
I need to know how many outputs are usable please with the kpro4, as i was limited before. Being the jap spec prc ecu.
I need fully programmable outputs using all peramiters possible for the following,
Nos
Watermeth
Rear diff activation(AWD CONVERTED)
Ethanol sensor
Aftermarket wideband
Thanks in advance
dc5itr01
Re: kpro4 outputs
Post by dc5itr01 »
I also need to connect 2 more Air temp sensors beside oem one.. Possible? Is it possible to read all 3?
Re: kpro4 outputs
You can open the software and see all the inputs and outputs available. There are ones not available on the PRC.
Ethanol content is an input on the K-Pro board.
You can also input a wideband signal on the K-Pro board.
dc5itr01
Re: kpro4 outputs
Post by dc5itr01 »
Thanks. Will check.
Will kpro read 2 extra air temp sensors?
Re: kpro4 outputs
No, you cannot add multiple IAT sensors unless they have a separate controller and an analog signal you can input into the K-Pro analaog inputs.
http://www.plxdevices.com/Air-Intake-Te ... 002214.htm
