last sunday i started my turbo s2000 year 2000 with a k-PRO on it for the first time....set my tps value....change my map for omni 4 bar.....everything was fine... let the car idle for 20minute.
On monday...try to restart the car ...engine won't start......??? took the laptop and take a look at the value...... tps at 103%.....ECT=177F.....IAT=95F...i took a look a the wiring diagram ...i realize they are on the same supply voltage SG3.... i took a DMM and read value at my IAT ...i got 5volt on green wire and 12 volt on red wire.....seem like ECU sending power on the signal side of the sensor
i believe the ecu is toasted....what do you guys think ????
help! tps 103%--- ect 177 iat 99--- key ON
Re: help! tps 103%--- ect 177 iat 99--- key ON
What is the serial number that is on the K-Pro board inside the ECU?
What exactly has been done to the vehicle besides the K-Pro?
05009042
omni power 4 bar map
throttle body 70mm skunk2
aem water meth kit(not connected in k-pro yet )
id 10000 injector
aem fuel pump 350lph...maybe.....rewired
aem wide band (not connected in k-pro yet )
id 10000 injector
According to our records this ECU was never modified for use in an S2000.
How is this being used in an S2000?
Can you post a picture of the inside of the ECU?
i saw the problem finally!!!....the ecm is toasted......for no reason....i ran the car 2 year without problems....REALLY disappointed.. i trust your compagnie ..now my s2000 is k-pro converted and stuck with that shit !!! give me you e-mail i will send you the picture ... i just funish my turbo setup and the stupid k-pro blew up .....woow !!! i spent 10 000$ on my car im not gonna spend another 2000CA$ for a self burning computer !!!!
You can email that to support <at> hondata.com
