Fn2 trip meter view 3L/100 km.
Hi, anyone knows how to fix the trip meter?
It worked like it should in october 2015 but now it doesn't work anymore...
Help?
Help?
Re: Fn2 trip meter view 3L/100 km.
You use a MAP-based calibration, not a MAF-based.
This feature only works on MAF-based (MAF or Hybrid), not on MAP-based (MAP) calibrations!
2008 Honda Civic TypeR FN2
Rotrex C30-94 supercharged with relocated IAT
Powered by ASNU 092/FP330E fuel pump & ASNU 090/750cc fuel injectors
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
You are using the wrong cal.
You must tune the car with the Civic-Si-RSP-7-FI calibration.
Import the all details from your Race MAP in the new one
Is MAP calibrations better than MAF ?
I am running a K24 with Comptech supercharger.
It worked in fall with MAP calibration, now my cruise control doesn't work either... :/
MAP is recommended for forced induction (Supercharger/Turbocharger), MAF is for N/A.goppe wrote:Is MAP calibrations better than AFM ?
MAP is more jerky in lower rpms/speeds (not as good in stop & go city traffic), MAF is less jerky in lower rpms/speeds.
MAP is better in WOT.
I'm running a Rotrex supercharged FN2 with a hybrid calibration.
I drive my car in everyday life, so I decided to use/run a hybrid Calibration.
More power output and less consumption!
This hybrid calibration uses variable MAF in part throttle (n/a) and MAP at boost (s/c) and in WOT.
Thats perfect for everyday use and sporty driving!
More comfortable and more sporty!
In addition, all functions (oil-level-indicator, consumption-indicator, etc.) are still present like OEM.
BTW:
The cruise contol only work, if you use the correct gear ratios for the FN2 like this:
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Cruise control didn't work...
My trip meter is actually moving but thats just it...:( I put in 1300cc at fuel economy.
How do I import my files to a MAF based calibration ? Have tried to select all and copy, then opened new calibration but it isn't copied then :/
Open your new calibration and import the parameters from your old calibration into the new calibration via right mouse click!goppe wrote:How do I import my files to a AFM based calibration ? Have tried to select all and copy, then opened new calibration but it isn't copied then :/
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Okay thank you, my cruise control didn't work with Fn2 gear ratios...
Hi , got problem when I was transfer this parameters into the new one. Right one is from the MAP calibration.
Do you put a hook on this?:goppe wrote:Okay thank you, my cruise control didn't work with Fn2 gear ratios...
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Yes I have...
Need help with these, there is no such thing in my MAP calibration.
Hi there, I am wondering if someone who knows flashpro good could look and see if I have missed anything ?
The things that are different from the MAP I haven't changed, I don't know what numbers to put in.
AFM flow/fuel are not supported in MAP-based calibrations, it is only a for MAF-based calibrations and not available in MAP-calibrations!
To edit/insert/delete rpms to import the correct parameters from your calibrations into the new, you can do this by right click on the row/column like this: All other parameters where you can not see under a MAP-calibration, are not supported by a MAP-calibration or only available at a MAF- or Hybrid-based calibration!
Why your cruise control does not work, I do not understand and I can not explain?
I think it is because you have to take a calibration for a FN2 as base?!
AFM = M-A-F (mass-air-flow) -based
MAP = M-A-P (manifold-absolute-pressure) -based
I hope you understand?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
