Car turns on but stalls as soon as I hit the gas
itrnate
Post by itrnate »
I Got my Type R tuned and it was running fine. I had it parked for a while now I turn it on and it turns on fine but as soon as I touch the gas it leans out and stalls. Also does not go pass 3k rpm. Could it be the TPS? I reset it the computer by disconnecting the negative to clear any codes and still does it. I don't see any codes in the computer. I don't know what happened?
itrnate
Re: Car turns on but stalls as soon as I hit the gas
Post by itrnate »
Video of car
Have you datalogged when this is happening to see what is actually going on?
itrnate
Post by itrnate »
Im going to do it tonight and I will post the data.
itrnate
Post by itrnate »
type r pump.skl
this is my map
itrnate
Post by itrnate »
Is my fuel trim in my tables low for low speed fuel. Or do I have to add to the tip in fuel?
The car runs fine when I step on the gas really slow and the full throttle but if I tap it real quick it leans out on me.
You have not posted the datalog showing the issue.
itrnate
Post by itrnate »
This is the datalog for the car. can you tell me whats wrong spunkster?
issue3.s3d
itrnate
Post by itrnate »
Please help
Make sure the you don't have the TPS and map sensor wires swapped.
If they are correct, you should adjust the TPS to be closer to a zero adjustment needed when calibrating it.
You could also have a fuel problem where the filter is either clogged, or the pump is not getting enough fuel.
Have you taken it back to the tuner that tuned this for you to have them take a look?
itrnate
Post by itrnate »
I will adjust tps and change the filter. I have a new aem e85 pump and rdx injectors installed. I will check with my tuner. It's started acting up after I swapped my igniter unit and downloaded my map to save it in my computer. My rpm was not working so I had to get the rpm signal from the driver firewall plug. Now the car is acting up.
