FlashPro Requests
Re: FlashPro Requests
Could you do one of the following?
1) Allow separate FlashPro datalogs to be merged
2) Allow FlashPro Manager to consider multiple datalogs for lambda / sensor overlays
3) Allow the user to select portions of a datalog to either ignore or remove (for the purpose of lambda / sensor overlays)
'06 NFR S2000
Could you add Fuel Status as a filter option for lambda overlay? Better yet, could you add that filter option to the tables window itself, so that the user can quickly toggle back and forth between open and closed loop?
'06 NFR S2000
I'm running TSX with second oxygen sensor disabled and wondering, is it possible to use its ECU input pins for 3rd party sensors (oil pressure\temp etc) to see it on display and make logs, like we're doing with eld - wideband input?
Gearhead98
Injector Sizing for fuel economy on the RDX.
Ability to rotate 3D graphing of tuning tables. Currently it's fixed orientation and sometimes that's not the best angle to look.
KillerKrossover
Please add fuel injection timing/end angle table.
Having tune other cars, this is a powerful tuning parameter. Low end to mid range power, fuel economy, engine starting, fuel smell, all can benefit from injection timing. The bigger the injectors, the more you can benefit from playing around with the injection timing. So please, please.
msangelfox
2014 civic si RBC manifold swap, skunk2 CAI, p2r throttle body spacer looking for something safe until I can afford the tune itself
Could you add this ECU number 37820-RX0-K21 ?
I can't use Hondata for my Civic si 2014.
Regards
César
Regards
César
[2006-2011 Civic Si] Added launch ignition retard and fuel enrichment
Can you please add this for the 2007-2011 FN2 Civic Type-R ?
Could you add the datalog timestamp value to the DDE sensors list in FlashPro Manager?
'06 NFR S2000
Make it possible to upload 2 or 3 cals to the ecu to make different driving profiles.
Controlling/selecting over the cruise control panel.
Can you please add fields for REV LIGHTS settings change? Two fields that set start rpm and end rpm where yellow/orrange rev lights start to appear one by one would be great.
Can you add the following 2 sensors please?
- IDLE LEARN - status
- FAN Switch - ON/OFF
Could be useful for doing Idle Relearn by yourself (knowing when the FANS engage and if IDLE RELEARN is Complete).
Euro Honda Accord CL9
Option to disable the knock control logic, like the kpro.
Is it possible to add the rolling antilag function or just use the existing lauchcontrol antilag as rolling ALS?
