ITR with greedy turbo sys.
kesnut
Post by kesnut »
i have ah friend with ah full greddy turbo sys. right now he is useing the e manage but will like to move to a k-pro. what changes do we need to make inorder for the k-pro to work. we are looking to run 9 and 18 psi on it
Thank you
kesnut
ares650
Re: ITR with greedy turbo sys.
Post by ares650 »
kesnut wrote:i have ah friend with ah full greddy turbo sys. right now he is useing the e manage but will like to move to a k-pro. what changes do we need to make inorder for the k-pro to work. we are looking to run 9 and 18 psi on it
Thank you
kesnut
Remove the emanage and the knock (little balck box) box. To run 18psi you will need a three bar map sensor and larger injectors. We have a RSX with a Greddy kit @13psi the car is seeing 72% duty cycle on 750cc injectors.
kesnut
Post by kesnut »
thank you...
any 3bar will do?
ares650
Post by ares650 »
kesnut wrote:thank you...
any 3bar will do?
I used a GM one with the motech settings.
