AUX 1 Configuration
H2RS
AUX 1 Configuration
Post by H2RS »
Hi,
I want to use the Aux 1 output for radiator fan control.
Output : A20 PCS
I put some conditions for the activation (Function : Generic output) :
Engine speed : min - 800RPM / Max : 9517RPM
Engine load : min - 100mbar / 17520mbar
Throttle : 0%
Vehicule speed : Min - 0 / Max : 158mph
Air temperature : -8°C
Water temp : Min : 0°C / Max : 150°C (just for the test)
But it doesn't work with my conditions. When I test with the test mode, It's working...
I don't understand why I can't control the fan with theses conditions!
Hondata V2, Soft : Smanager 2.3.7.0
Thanks a lot.
Rom.
Re: AUX 1 Configuration
Can you post the calibration and a datalog?
H2RS
Post by H2RS »
Here, I'll find the map.
Thanks.
The arming input needs to be 'Always On'.
