hey guys need some help i got the new firmware updated on my flashpro manger, now my flashpro wont unlock from my car
all it does is make a windows error noise when i press unlock, no error messages pop up i am not even sure the return ecu to stock is working when i press that it just makes a ding noise. does any know know how to fix this?
its for a acura tl 2008 type s and the serial is FP-TL-US-140021
thanks
can't unlock from my car
Re: can't unlock from my car
i am using version 2.2.9.0
Try the following steps:
#1 Connect FlashPro to your PC (USB/BT)
#2 Open FP Manager
#3 Select: Online > Return ECU to stock
Important!
#4 Go to your car
#5 Flash your ECU to bring back the stock condtions...
#6 Connect FlashPro again to your PC
#7 Know unlock from vehicle
I hope it helps
#2 Open FP Manager
Important!
#4 Go to your car
I hope it helps
When I plug the flashpro in and press return ecu to stock it doesn't load anything it makes a windows bell/ ding noise? Could it be the firmware? I sent hondata the information
also when i go to help and press on the check internet connection i get the same windows bell/ding noise nothing pop up saying conection ok
Have you tried a different laptop or a desktop computer?
i dont have a destop i just got another laptop downloading flashpro manger right now did you guys recieve the infomartion i sent from flash pro manger?
Ok I finally got it unlocked used another laptop and it worked perfectly thanks
