Hi guys I have a boosted facelift ek9 and I'm having an issue with boost control solenoid. I'm using a p30 ecu with s300 and jumper harness. The hondata info says for jdm ecu use pin a17 and have the other wire through a switch to ground. Or. U.S. Ecu use pin a11 with switch to 12 volts.
Is a p30 ecu regarded as U.S.? It originally came out a UK car and is the longer case type.
Rob
Boost control p30 ecu
Re: Boost control p30 ecu
Take a photo of the inside of ECU maybe some one can look and tell you what's up, but the rectangular ECU needs components to be installed to be able to control boost
hi thanks for the reply. I have the boost control hardware installed already.
Well in that case use A11 pin and test if it's working with test output feature in SManagerrobthedoc wrote:hi thanks for the reply. I have the boost control hardware installed already.
