S2000 Kpro4 and RSX wideband
Now that Kpro 4 supports wideband feed back, can you wire it to use the RSX wide band sensor directly to Kpro4? Or is an analogue input the only way to make this happen?
Re: S2000 Kpro4 and RSX wideband
Using the analog input will be much cheaper and easier as no relays or additional wiring is needed.
