Hi,
I have been looking for a PRC ECU to have Kpro installed to use in my K-swaped EG using a K20A. I found one online ("batch fire" k20a PRC-013 ecu). Can this ECU be used for KPro? Is there anything special I need to do it or can I just send it in to have KPro installed? I wasn't sure since the ecu has been modded to batch fire.
Sorry if this an ignorant question.
"batch fire" k20aR PRC-013 ecu for KPro (EG Swaped K20A)
the_goblin7
Re: "batch fire" k20aR PRC-013 ecu for KPro (EG Swaped K20A)
"Batch Fire" sounds a lot like the ECU has been damaged and is running on the internal backup processor. This is not an ECU you would want to buy.
the_goblin7
The seller claims it means the ecu has been reprogrammed to spary all 4 injectors at once instead of one at a time. Sounded strange to me. Not sure why you would want to do that.
Nope, it's damaged. Judging by the photo of the ECU which has 'NFG' written on it, someone agrees.
the_goblin7
Awesome! Thanks for all your help!Hondata wrote:Nope, it's damaged. Judging by the photo of the ECU which has 'NFG' written on it, someone agrees.
