need basemap for b16a
I have a b16a with Blox 68mm throttle body, Blox intake manifold, ITR cams, 4 to 1 Greddy headers with 2 1/2in exhaust no cat. stock injectors as of right now with golden eagle fuel rail, bwr fuel regulator. fuel pressure is at 42psi, its as low as i can get it but my car is still running on the rich side. i can smell gas out me exhaust. my wideband is around 10.0-10.5 at idle. right now Im running a stock base map. can some one help me out?
Re: need basemap for b16a
May or may not work.
Give it a try.
Give it a try.
07 Civic Si Sedan (sold)
17 Civic Si Sedan (daily)
02 RSX Type S (project)
Hit me up for free Hondata Help!
thanks for the map i appreciate the help. it seems to help some. my wide band is now at 11.0-11.5 at idle shouldn't be in the 12s?
Naw man idle should be around 14.7. Pretty much everywhere should be 14.7 except heavy cruise and wot (columns 8-10 generally). WOT should be between 12.5 and 13 IMO.
Double check that your wideband is correctly calibrated and then start slowly pulling fuel from the idle area or adjusting the overall fuel trim.
Also I think I forgot to remove the post start fuel so 0 that out too. Oh and cylinder 4. My car ran a bit leaner on cylinder 4 (from plugs) so I added 2% for that.
Try this and report back. I'll keep an eye on this thread
i have a aem wideband 30-4100. i have the power going to the fuze box, the ground is going to D22 on the ecu and the white is going to D14. what do i need to do on SManager? im still new to having s300 and wideband. learning as much as i can on my own.
You have to go to closed loop tab under parameters and dial in your voltage readings.
Did you make any of those changes?
i did not. because i was not sure what to change them to. thats where im stuck at this point.
All good I'll shoot you a new map when I get home
ok thanks again. if you need any more info about my car let me know.
my last datalog
That datalog doesnt show up for me at ALL.
Anyway, heres a new map. It will at least you get you started.
ok thanks ill try it out tomorrow. its raining out now. ill try and send you the datalog from it.
i went out for a drive on the new map this morning
What version of SManager are you using? I cant see your logs
I have the latest up date Smanager my s300 is the old version not v3. I've had it sense 1994
