cooling fan will not turn off
FlashPro Manager software
reneruvalcaba03
Post by reneruvalcaba03 »
I had my flashpro tuned and car dynode at a shop, ever since then the cooling fan on the car felt a little different but now the fan got stuck in the on position wether the car is on or off the fan stays on, the only way it turns off is if I disconnect the battery from the car. What can be going on, ive had it installed along with skunk 2 intake manifold and a throttle body for about 4 months now but it just now did this out of nowhere.
Alex_FN2
Re: cooling fan will not turn off
Post by Alex_FN2 »
did you use ECT2 ecu input to connect any other device there?
if you did you had to disable ECT2 cooling fan radiator control,it's an option on misc on the calibration file.
if you are not sure for anything stated above contact your tuner in order for him to check your calibration.
ipalpha
Post by ipalpha »
Did you ever find out what caused this or fix it?
