Gear compensation
FlashPro Manager software
sass
Gear compensation
Post by sass »
This table allows the ignition timing to be altered by gear. Positive values will advance, negative values will retard. Note that the ignition timing is change for all load and rpm values in each gear.
We have an issue: ignition timing not working for all gears and does not matter which racing maps we use.
Calibration
FG2/FA5, MAP based, Deatschwerks 1000 injector starting calibration
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
Re: Gear compensation
Please post your calibration and a datalog of the problem.
sass
Post by sass »
ok
Known as Sniper
It is because the knock ignition limit is 60. Setting it to 0 will allow the gear ignition compensation to work.
sass
Post by sass »
What's next?
Known as Sniper
Check
Ignition -> Air Temperature Compensation -> Ignition IAT Applied to Ignition Advance
sass
Post by sass »
bingo
Known as Sniper
Good. I've updated the help file.
sass
Post by sass »
thanks
Known as Sniper
