2013+ Accord Flashpro
sds
Post by sds »
Is this on schedule for the start of this month? I see that any mention of it was removed from the Hondata news page.
Re: 2013+ Accord Flashpro
The 4 cylinder is done and released and the we're still working on the 6 cylinder.
sds
Post by sds »
Hondata wrote:The 4 cylinder is done and released and the we're still working on the 6 cylinder.
Do you expect to have speed density/VE fueling on the 6 cylinder models?
Yes. The difficulty factor is that some have two copies of the ignition & knock tables for VCM.
sds
Post by sds »
Hondata wrote:Yes. The difficulty factor is that some have two copies of the ignition & knock tables for VCM.
I see how VCM would get in the way...well I have a 2015 V6 6MT and I'm anxiously awaiting flashpro, so hopefully it'll come out soon.
sds
Post by sds »
Is this fake?
It is real, we are dynoing the V6 this week.
sds
Post by sds »
Hondata wrote:It is real, we are dynoing the V6 this week.
Great! Keep me in the loop? (As if I'm remotely important...)
The V6 is pretty much done. There's a set of closed loop & injector sensors for each cylinder bank, and in VCM mode you can see one bank shut down with the injector duration going to 0. Front and rear banks run about the same lambda and fuel trims most of the time. You can also switch off VCM operation if you wish.
We have to get the calibrations & dyno information together for release, which will take about another week.
Accorddict
Post by Accorddict »
how about INT VERSION?
for K24W4 T_T
cesthree
Post by cesthree »
Hello,
Can you please tell me if the Hondata Flash Pro will work with the Honda Crosstour V6?
An example ECU part number is 37820-R53-A75, and that is for a 2014 Crosstour AWD V-6 EX-L. I'm not sure of variances in other model years, but the Crosstour switched the V6 to the Earth Dreams starting in 2013.
If the Flash Pro is not compatible, do you have a different model programmer that would work?
I'm interested in tuning, and I know others are interested in disabling VCM without "tricking" the engine temperature sensor signal to the ECU, like some creative folks have offered as a "solution".
Thanks in advance!
Sorry, we have no tuning solutions for the Crosstour.
cesthree
Post by cesthree »
Thanks, but that's sad news. ;(
