Sry my english is bad.
I have a problem when the temperature outside is below 0 degrees, the pressure does not rise above 0.3 bar. What could be the matter?
Cold air will not boost
Re: Cold air will not boost
The throttle is never opened fully.
If the AF is accurate then 13.5:1 under boost is very lean.
What is your wastegate setup?
Activation pressure 1,68 bar.
When the weather was warm, it was fine but now it's cold, the mixture goes lean. The calibration of the first post.
Thanks Reiko
Thanks Reiko
Can anybody help?
Had a faulty ignition coil!
Thanks for the update. I guess that would give a very learn reading in the wideband.
forevertrj
- Contact:
yea thanks for the update, also i never saw the car go WOT or even above 80% throttle, also things I noticed that should probably be corrected is the overall fuel trim should be brought back down to 0% and then move the fuel tables down -13% then re adjust, also your fuel table lines are so jagged like mountains where they should be smooth like rolling hills, by smoothing them out you'll get a much smoother ride on your throttle.
