R18 Speed limiter still enabled - Please disable
nyghtstalkr
At one point, the R18 Flashpro had unlocked the Speed Limiter (over 1.5 years ago). It is and has been enabled for quite some time now. Please remove the Speed Limiter in the R18 Flashpro. Road course racing sucks when you get passed because you are banging speed limit on a mile long straight away.
Re: R18 Speed limiter still enabled - Please disable
What year and type (AT/MT) R18 do you have?
nyghtstalkr
2008 AT. This happens to AT and MT alike, Road tested and dyno top speed testing.
reaperdwarf
I wish hondata would let you control the speed limiter i have this problem all the time please disable the limiter
nyghtstalkr
On the Si Flashpro, you can enter a MPH value for he speed limiter. That doesn't exist on the R18. It was just disabled. However, during one of the updates 1.5 years ago - 2 years ago the speed limiter was engaged again.
We'll look at this and fix for the next release.
nyghtstalkr
Thank you so much fellas!
One side question. Are you able to add BBG to the Flashpro for us boosted guys? Just curious if that is a possibility. I personally am sending my block to CNC Werx to be built and will be running a GT3071R after and I would like to be able to hold traction in 1st and 2nd gear.
reaperdwarf
I would also like boost by gear on the r18 also boost control on the actual hondata with the solenoid would be great
