need a good basemap please help
lsv turbo 70 trim 63ar id 1000cc injectors 70mm s90 tb hondata s300 v2 ecu in a p28 hondata 4 bar map sensor 14lb spring in wastgate weisco 10.5;1 compression css sleeves manlet turbo tuff ibeam rods motor is fully built problem is it will not idle at all I hold the pedal to the floor car has no throttle response and falls on its face and dies after a couple seconds please help thanks in advance
Re: need a good basemap please help
post the startup file that you are using
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
Lgmotoring.com
start up file? how do i go about doing that? sorry im new to this whole thing i would appreciate your help
