Throttle tip-in
FlashPro questions & answers specific to the 2007-2008 Acura TL
DomGSR-T
Throttle tip-in
Post by DomGSR-T »
Anyone has a throttle tip-in problem from 1% throttle to 0% on very light throttle? It creates anoying jerking of the car...I had that problem sometime going downhill with my stock TB but with the ZDX TB the problem is always there but not on 5th and 6th gear. Anyone found a way to fix that? Thanks for your time!
J30 6spd
Re: Throttle tip-in
Post by J30 6spd »
DomGSR-T wrote:Anyone has a throttle tip-in problem from 1% throttle to 0% on very light throttle? It creates anoying jerking of the car...I had that problem sometime going downhill with my stock TB but with the ZDX TB the problem is always there but not on 5th and 6th gear. Anyone found a way to fix that? Thanks for your time!
Yes, I have this problem as well! My car jerks a lot in each and every gear. It's less in 5th and 6th but it's still noticeable.
reallyflyguy
Re: Throttle tip-in
Post by reallyflyguy »
I fixed mine. things to change...
You need to increase the "overrun cutoff MAP low cam". Do this very slowly until it feels better. Like 0.001 small increments.
Then you also need to set your overrun fuel cut delay to about 50... you're choice on that.
Last I increase the throttle tip-in retard. Mine is no lower than 50.
