A/F RATIO EUROPEAN CTR
Hi ,i have a european ctr with k-pro.what i nead to buy for tuned correctly the a/f .i don?t see the corect values in my dalalog sensor(af and afcmd).sorry for my bad inglish.thanks
You need a wideband lambda. A good and working setup is to replace your secondary lambda with AEM UEGO, and route the analog 0-5V output from AEM to ECU's SO2 input. By doing this, A/F ratios can be monitored while driving with the gauge, and also datalogging the A/F works great! Downside is that in datalogs A/F is shown only as a SO2 voltage value, but it's no big deal. Also, OBD II must be disabled to turn off the CEL caused by removing the secondary lambda.
http://memimage.cardomain.net/member_im ... 3_full.jpg
http://memimage.cardomain.net/member_im ... 4_full.jpg
