s300 v2 red board analog input
doc_763
Post by doc_763 »
Can the s300 v2 red board analog inputs be used for plx wideband tuning?
Re: s300 v2 red board analog input
Yes.
doc_763
Post by doc_763 »
Does yes mean it can be used for closed loop running of the engine
No, it is for datalogging only. You must input the wideband signal into one of the ECU inputs to run closed loop.
doc_763
Post by doc_763 »
I have tried the ecu analog inputs B6 and D10 but I cannot get it to operate. D10 is showing 4.55v continiously with nothing connected to it. B6 analog2 input is showing between 1.2v-1.9v. I have connected my plx wideband to b6 analog 2 and it then turns on the A/C switch on the s manager but i dont have A/C in my car. I have changed the offsets but to no success. Can you help me with this?
B6 - http://www.hondata.com/help/smanager/an ... sub=analog
D10 - http://www.hondata.com/help/smanager/wi ... ghtsub=d10
Whatever input you use can no longer be connected to it's original location. Cut or de-pin the wire and wire the wideband signal directly to the ECU.
doc_763
Post by doc_763 »
i have currently tried all available analog inputs to the ecu. none of them are working for me. i have removed resistors R2 R3 R136 and R138 but still nothing working. the last input i tried was D12 and i depinned what was connected to it but then i got fault code from IAT and ECT sensors. hopefully you can be of some help to what my problem may be. i have done everything explained on S300 help file online.
It sounds like you may be wiring things to the wrong pins. You may want to have a friend take a look at this with you as they may see where you are doing something incorrectly.
doc_763
Post by doc_763 »
I have had someone check it. Been a long day will check again in morning. Thanks for help
