All nitrous options to all ecus (i have PRC)
Honda
Post by Honda »
Hello. I m trying to add nitrous options (inputs B9 E16 E22 E29 and outputs B6 E18 E20 E21) on a PRC ecu (B9 doesnt have all components from factory for example as is writen in kmanager). I d like to have them all added. Can someone please provide me with information from the PRB ecu that (i think) there are all added from the factory. Something like diagram with the components...
INPUTS
VTP (secondary AC input) B9 (GND=off) this is NOT complete in PRC
Power steering press E16 (GND=on)
Brake switch E22 (12V=on)
Service check conn E29 (GND=on) this exists on all ecu i think
OUTPUTS
FANC Fan control B6 (GND=on) ?
ACC AC Clutch E18 (GND=on) this exists on all ecu i think
2WBS EVAP bypass E20 (GND=on) this exists on all ecu i think
VSV EVAP vent E21 (GND=on) ?
ok maybe i can copy the existing outputs, but for the inputs? Can someone confirm?
if i buy a PRB can i transfer the Kpro board to it from PRC?
Thanks!!!
Honda
Nitrous routines verification
Post by Honda »
Can some1 from hondata verify that in the PRC/PRA rom all nitrous routines exist?
So if i add the missing components ti will work?
05typeR
Re: All nitrous options to all ecus (i have PRC)
Post by 05typeR »
http://hondata.com/ecus.html
Nitrous pins wont work on a PRC
Honda
Re: Nitrous routines verification
Post by Honda »
Honda wrote:Can some1 from hondata verify that in the PRC/PRA rom all nitrous routines exist?
So if i add the missing components it will work?
If i add what i s missing behind the pins it will work?
