Disabling all ignition knock for race motor
FlashPro Manager software
candal82
Post by candal82 »
Hello,
We have a high compression S2000 race motor that is running on 112 octane leaded oxygenated race fuel. We would like to disable the ecu from changing ignition timing, and want it to read ignition values from the main ignition tables.
What is the quickest and most effective way to do this in Flashpro?
Re: Disabling all ignition knock for race motor
Set the knock ignition limit tables to all positive numbers. Set the ignition retard tables to zero.
candal82
Post by candal82 »
Thank you kindly.
