Knock table problem
iketh
Knock table problem
Post by iketh »
I can't lower timing at 5500 rpm at 30-40 degrees with the knock tables. I've gone all the way down to -16 at 5500rpm 40 degrees and timing remains 25 degrees when the table is set at 26. Example is 2:37.7 of the attached log.
Also, can we get the knock tables to automatically change from low to high when viewing logs?
iketh
Re: Knock table problem
Post by iketh »
never mind I figured it out :)
