Setting Injector Dead Times
Hey. Ive got a s300v2 with ID1000 injectors. the dead times for these injectors are in µsec and in hondata are in MS. ive heard that the dead times arent quite right anyways? Whats the best way for setting them?
Re: Setting Injector Dead Times
The best way to set them is while the engine is running at idle, while dataloging, set your deadtime according to the voltage registered. Then turn on your lights on to get the voltage to drop and set deadtime. Then turn on maybe your heater blower motor. Also wait for you radiator fan to come on. Key is to try to get the voltage close to where your scalar is in your parameter. As your setting your deadtime, you're trying to maintain the same AFR. Kind of hard to explain, but it works. lol
