Some questions about s200 on b16a2
nutchee
Post by nutchee »
Hi all :D
I would like to know what i need to tune in the best way my Hondata s200 ecu. I'm confused about Romulators, Programmers and Editors.
Can you please explain me wich components do i need to mapp my ecu?...and what about the emulator?
Thank you all.
Regards..
DaX
Post by DaX »
First off you'll need a wideband lambda meter so that you can monitor your AFR's.
I assume you already have the Hondata S200...you'll need datalogging capabilities and you'll need ROM Editor software.
You'll also need either a ROM Emulator and a ROM burner, or just a ROM burner. The emulator just allows you to make changes without having to re-burn a chip after every change.
Tuning the timing is best done on a dyno.
nutchee
Post by nutchee »
There is no problem about burning the same rom many times right?
So i need:
ROM Editor V3
Romulator realtime emulator
Programmer
Right? :(
